Aes 390 / F1A results?
#61
LS1Tech Sponsor
No, two totally different blowers. Thanks. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
#63
LS1Tech Sponsor
For your elevation you could indeed stand to have a little more compression. Have you experimented with adding a little timing to it? The new head unit would take away a little of the low end, as will any head unit larger than your current F-1A. It does have the same 5.40/1 gear ratio, and same 74,000 impeller speed. Questions are never a problem, Andy. Bob
__________________
#64
Bob, another thing I told Andy to consider is our DA rarely gets below 6000'. I also told him to run straight MS109 and bump the timing. FWIW on my 346 with my novi 2200 spinning to the max I see around 17-18 pounds.
#65
LS1Tech Sponsor
DA of 6000, that really sucks the life out of an engine!!! More timing would definitely help. Good info, thanks! Bob
__________________
#67
LS1Tech Sponsor
You're welcome, Andy. Let us know how it does. Bob
__________________
#69
Restricted User
Wait, you maxed out 80 lb injectors and had to go bigger? But are only trapping 130? The last time I seen 80s maxed, traps were 150-155 mph @ 3600 lbs. Check your fuel pressure.
You've got a major issue somewhere. Throwing handfuls of money at it isn't the answer.
#70
LS1Tech Sponsor
Keep in mind Andy is at high elevation, which changes everything. Bob
__________________
#71
i agree. we have the same injectors but im on e85 and my duty cycle on the same night was 68%. i trapped 144 that night and run a base pressure of 60psi. i do have twin 15 meth nozzles but i still think something is up.
#72
Restricted User
Altitude forces you to use less duty cycle because you aren't moving as much air and therefore less fuel.
80 lb injectors at a 58 PSI base pressure (boost referenced) are good for 1000+ flywheel HP. At 70-76 PSI base pressure you could make close to that on E85.
80 lb injectors supplemented with Meth are capable of 4 digits to the wheels. The fact that he is maxing them out at that high of an altitude and trapping 130 says he has a major issue in his tune or his fuel pressure is down dramatically. I've trapped mid 140s on 60 lb injectors and meth injection.
I'm almost starting to think one injector isn't firing, forcing him to run the others rich just to hit target AFRs and thats why his duty cycle is so high.
#74
Restricted User
I'd almost be willing to bet he's running on 7 cylinders. He's using tons of injector, and only trapping 130. One of them isn't likely firing. Since he has since upgraded injectors, its probably a harness issue and needs to be tested.
