5.3 turbo build for 67 camaro rs opinions needed
my friend wants me to build a 5.3 single turbo meth injected no intercooler .factory a/c car, keeping a/c, 80 mm turbo how much power will this make ???
Are you going to be spraying 100% meth or is it blended with water?
A 80mm turbo will make good power but the fuel and the meth will dictate how much of that power you can safely use.
500-600 at the tire won't be to much to ask. Can you make more? Sure you can, but how realistic do you want to keep it.
Turn up the boost and your margin of safety gets smaller.
I,m starting to get parts together for this build I have a 08 5.3 block not sure witch ls1 heads I have yet, ls 6 intake truck manifolds. 500 to 600 to the wheels is ok for cruzing around town I would like to bump it up when I want too safely. with what I plan to do will that be ok or will I defiantly need a inter cooler
