Fan wiring help ?
Old 03-13-2014, 01:49 PM
conan's Avatar
Default Fan wiring help ?
So I'm getting ready to rewire my fans, I have added a small fan to the single procharger shroud.
The original wiring harness in the car has the following 4 wires...
Blue - wire
Grey - wire
These 2 wires go together in the original dual fan shroud
Black - wire
White - wire
These 2 wires plug in to the other fan in the original dual fan shroud.
So my question is what wires are for the primary fan and what wires are for the secondary fan ?
Question 2 is what color wires are positive (+) and witch are negitive (-) ?
Thanks guys...
Chris
Old 03-13-2014, 02:41 PM
jjcamaro02's Avatar
On the left hand fan the light blue is + and the grey is minus.
On the right hand fan the white is hot and the black is ground.
On low speed the fans run in series so the left fan is grounded through the right fan (thats why run at 1/2 speed) and on high they are both grounded.
You may have to reverse the wires, it wont hurt to hook them up backwards so make sure the are spinning the right way.
Old 03-13-2014, 03:32 PM
conan's Avatar
Thank you sir...
Old 05-14-2015, 10:59 PM
one fast zo6's Avatar
good info
Old 05-15-2015, 10:24 AM
conan's Avatar
Originally Posted by one fast zo6
good info
Yes it was, wired up the 2nd small fan just so... Been working fine for 2 years.
Old 05-18-2015, 01:03 PM
Firehawk441's Avatar
http://www.ebay.com/itm/TPI-LT1-LS1-LS6-Fan-Connector-Kit-Camaro-Firebird-Corvette-/121049003426?hash=item1c2f1535a2&vxp=mtr
Use these female connectors on your aftermarket fans and they will plug directly into your factory harness.
Quick Reply: Fan wiring help ?
