AMS-500 With TT and 2 Gates
Just wanted to run this past some of you who may have plumbed this setup. I created a visio flow chart for how I plan to run my setup. Does this look right?
no need to use the vacuum provision on the bottom of the gate. That can vent to atmosphere. If you use that provision in your drawing you'll never be able to make more than double your gate spring. I assume your planning on making some big power being your using co2. You could more than double your spring using C02 but you would go threw a lot of it depending on what your using your set up for. This is my opinion from my own experience using the AMS 500
