Spool valve for a diesel work work for gas?
Old 03-26-2014, 06:15 PM
69-chvl's Avatar
Default Spool valve for a diesel work work for gas?
Attachment 443879
This valve is 600.00 but looks extremely well made and adjustable. Says its for a t4, would this work good on a s475??
Old 03-26-2014, 06:25 PM
HexenLord's Avatar
The spool valve doesn't have a fuel sensor in it that detects whether its diesel or gas.
In principle, it'll work for either diesel or gas. You can find them much much cheaper than $600 and they've been proven to work. Although you can make an S475 spool pretty fast without the need for something like this...
Old 03-26-2014, 07:22 PM
dmaxvaz's Avatar
that spool valve is for diesels because they run higher boost pressures than turbo lsx's(50+psi) that valve probably will not open at peak boost for us. sound performance makes one for gassers that use solenoids and or cO2.
Old 03-27-2014, 04:53 AM
95bowtie's Avatar
Who else makes/sells spool valves besides sound performance?
Old 03-27-2014, 05:43 AM
JAX04's Avatar
This was big once upon a time here. (lots of talk, but not many people were doing them)
Do a quick search for Spool valves, and there was tons of threads about them a few years ago. Quite a few guys have done this same thing with a wastegate as well.
Old 03-27-2014, 05:57 AM
HexenLord's Avatar
SP is the biggest name in spool valves. Lots of other companies make their own. Search for them on this forum. There were a few sponsors that were selling them here a few years ago. Zombie did a test on one a while back with very good results.
Then there are the knockoffs.
Quick Reply: Spool valve for a diesel work work for gas?
