How do you know a converter is right?
Old 07-05-2014, 02:02 PM
69-chvl's Avatar
Default How do you know a converter is right?
How do you know when its close to being right or wrong?
Right now, mine drops 1000 rpms on the 1-2 shift, and 500 rpms from 2-3. Feels pretty good driving around, spools nice. Will hit the dyno rollers next Sat, track right after for some more data.
Old 07-05-2014, 06:56 PM
turboventura's Avatar
There's a few calculators online for you to figure out converter slip. Trap speed/gear/tire diameter/gear ratio.
Old 07-06-2014, 01:13 AM
8 Second Truck Club
Blown06's Avatar
1000 on the 1-2 and 500 on the 2-3??? What rpms are you shifting at? Typically they are a lot closer than that unless the shift rpm is different.
The "right" converter is different for what combo you are running....I can tell you this, a procharged car will want a way different converter than a turbo car.
Most converter companies will give you acceptable rpm drop and slip numbers as they see fit. Now some companies will not agree on what is perfect. Getting a converter 100% right for a particular set up can be a daunting task as it can almost always be improved.
Old 07-06-2014, 08:44 AM
69-chvl's Avatar
Shifting at 6000 during the 1-2 shift. I will be hitting the chassis dyno on sat for a little more data.
Old 07-06-2014, 08:49 AM
samdogmx's Avatar
mines drops 1000 on both shifts and has 5-6% slippage at the stripe.
Old 07-06-2014, 06:19 PM
69-chvl's Avatar
What converter/specs? Wondering how you can drop that much rpm on the 2-3 shift when the ratios of the trans are much closer there.
Old 07-06-2014, 07:07 PM
RonSSNova's Avatar
I just checked my data log
1-2 from 6500-5750 = 750rpm
2-3 from 6775-5920 = 855rpm
Ron
Quick Reply: How do you know a converter is right?
