Fan Wiring, Derale 16925
So I am in the process of wiring 2 fans. I searched and came up with pins 42 and 33 as the high and low triggers for the factory relays. I was wondering, if I bypass the factory 3 relays and tap directly to those pins and use them as ground triggers, would the fans work properly? i.e. pin 42 to 86, 85 and 30 to 12v, and 87 to fan 1. Pin 33 to 86, 85 and 30 to 12v, and 87 to fan 2. I can delete the codes through hp tuners.
