Fairmont 5 - 6-28-15 SOLD
#183
speaking of degreed cam some time last month you were asking about degrred cam data due to a car not making power you expected ?????? what was the out come????? was it the cam??????
#186
oh look at that
i have this in here, mocking evertything up and taking a measurement for my friend to cut the pan.
longblock only on the suspension, coil half way up
my friend tony built the hotside in south dakota, and im on the east coast, and it dropped right in. amazing
china pt88
forgot to install my center cap, this is hotside, turbo, radiator etc
china pt88
#187
Dude, where's the "sloppy" on this one?!?!?! Lol
I love how the truck intake fits under the hood with the tubular K member. Does it fit in a fox body mustang too?
If you fabbed up some "bump steer correcting spacers" for where the tie rod connects to the knuckle, could you drop the steering rack and not have to notch the pan?
#188
After all of the previous builds...I'm curious as to how much faster you're planning to go. All of these shiny parts are definitely nice though. Mark's car must have you motivated.
#189
Bumpsteer.. Rack? Looks like he is cutting the pan because he is going to smash it after it hikes the wheels for 100ft or so.
We need to just start the fund for the 25.5 chassis now.
#191
i told him where i wanted the turbo and we went back and forth on a few things and decide on what it is, i just told him i wanted driver side and orientation and he took care of the rest, pretty incredible since he doesnt have anything with this k member and didnt know exactly where anything would be.
this is the other kit he built me
#192
i can answer both of these questions together.
i guess the point is to see if a more race oriented car is worth the squeeze
im going light, and using nearly the same setup china turbo and stock 5.3.
yes nearly any aftermarket K lets you fit the truck intake, since it puts the motor so far down and back.
costs a little more for the k member but whats nice is you dont have to break the bank getting the car intake bare, rails, lines, regulator, intake gaskets etc. its almost a push, i figured while i was at it, **** it, tube A arms, coil overs, and the works.
#196
weighed my car today with alot of the same weight reduction you are doing, (4.8,th400,gt45,no hvac,tube k, coilovers blah blah) came in at 2920 with me in it (145-150). i dont have a cage and its still on stock 14s with the 7.5 but just giving you an idea. cant wait to see how fast you go with this one.
#199
that makes me pretty excited for this car to be 3000 with me in it
#200
operation mini frame rail today
pretty close to teh turbo and drain and this will make it much easier to reach all of that and easily be out of the way
also pulled the gas tank, and i sprayed everything with penetrating oil so i can get the rear loose then, removed exhaust and driveshaft and 20lbs of mud and rust.
