Fairmont 5 - 6-28-15 SOLD
#1121
I alldata'd the push rods for a 09 Yukon with a 5.3 (should be Alum 5.3) and the Part number is 10238852. They come up a 7.325" Length - http://www.gmperformancemotor.com/parts/10238852.html
#1122
last 10 digits of VIN on left side deck just rear of head
#1124
Lol no theres an actual flat spot behind the head on the block above where the trans mounts i know in like a yukon to see the number i have to use a mirror so depending on how close the motor is to the firewall you might have to use a mirror to read the number
#1129
PS It's not like he's just going w/ factory stuff across the board for that Ford.
#1130
i have truck bracket and truck alt on truck accessories
i threw the car on and it did 480 on 8psi and 570 on 18psi...
i came home and pulled the aluminum motor out again
took apart the 6.0 that had the questionable cylinder and there was a cracked ring, i have replacement rings from other motors, i threw one in there, going to put that one back in now, with different heads, swap the valvesprings over etc etc
joy!
joy!
#1132
Matt, Do you have a graph that might be able to help see if you have convertor slip????? 480 to the wheels at 8 psi doesn't seem extremely off and then 10 more psi only adds 90 hp is there a chance that the added 10 psi of boost is blowing through the convertor????
Kerry
Kerry
#1135
So boost holding now on dyno, good. Would be great to see any graphs you have to better understand what's going on. Thanks for sharing the learning journey!
#1137
i pulled the alum motor when i got home
took apart the 6.0 i have also, found a broken ring in the middle of cyl 8 on the 6.0
replaced it, ill be putting that in, with the 228 cam, swapping the valvesprings over to some stock 317 heads i have, and stock 6.0 head gaskets i have, and then throwing in some head studs i have laying around, just for fun,
so this way the block, heads, springs, gaskets, fastners will all be different
#1139
