Alternator wiring
Old 07-20-2014, 06:53 PM
vht
vht's Avatar
Default Alternator wiring
I'm using the 2000 6.0 alt in my foxbody. Anyone have any info on wiring it up? It has P L I S where my connector plugs in. I'm running the bat wire to the pass thru terminal on my firewall that the bat cable hooks to. I know L is lamp, I is the exciter terminal. I remember something about resistors having to be used so I figured I'd better ask. I thought Denmah had something about this but I can't find it.
Old 07-20-2014, 09:10 PM
Hi-Po's Avatar
I just wired up my one wire alternator. Might be different then yours. All you have to do is solder in a 470 ohm, 1/2 watt resistor in place and connect to switched power source.
RadioShack has the resistors.
Old 07-21-2014, 06:13 AM
forcd ind's Avatar
P isn't used, S goes to the large bat term on the alt, and I get F & L mixed up
I think F gets switched +12, and L gets the rest. or the lead from the idiot light on the dash, but don't quote me on that, going from memory
some plugs are listed as 1234, or ABCD
Old 07-21-2014, 11:34 AM
vht
vht's Avatar
Thanks
Quick Reply: Alternator wiring
