370ci turbo build questions
Old 10-04-2014, 09:12 AM
IMPRTKILLER's Avatar
Default 370ci turbo build questions
I am building a 6.0 iron block with stock 317 heads and a TU2 cam. My turbo is a s475 T6 housing and was wondern what size Pistons i will need for my build. I found these Pistons a guy has and was wondern if they will work. They are (-3.2cc dished/4.005) comes with GFX rings. And the H-beam rods are 6.125/ Pistons have a 3.622 stroke. Please help guys. Oh ya and this motor will be on e85 also.
Old 10-04-2014, 10:00 AM
4bangermustang's Avatar
as long as the bores on the block are good and you can go to 4.005, they will work. Would be a higher compression setup depending on the heads you use.
Here is a good thread to figure out your compression.
https://ls1tech.com/forums/generatio...alculator.html
Quick Reply: 370ci turbo build questions
