Microsquirt experts get in here. Can bus questions
Old 11-01-2014, 04:28 PM
kjm
kjm's Avatar
Default Microsquirt experts get in here. Can bus questions
Would any of you know where I can get the can address for the microsquirt functions. Like
Timing
Coolant temp
Map sensor
Rpm
Charge air temp
I see it has a can high and can low. So I would think all those parameters would have an address and be available on the bus???? I have an ecu that I'm using to control boost and water meth injections, bump box so when boost reaches a set pressure it will bump me in automatic
And also used to log wheel speed and things like that. I would like to grab the microsquirt messages and bring them into my ecu controller. Has anyone done this or know if the messages are broadcast on the bus ?????
Thanks Kerry
Old 11-01-2014, 04:36 PM
junkbox's Avatar
Denmah is the guy u need to either message or get in touch with i believe he knows the microsquirt stuff really well
Old 11-01-2014, 04:53 PM
kjm
kjm's Avatar
I will text him. Wasn't sure if he had ever got that deep into it
Old 11-01-2014, 09:23 PM
Moderator
denmah's Avatar
yeah i dont know anything about the canbus part, best ask on the megasquirt forums or call EFI source for the info
Quick Reply: Microsquirt experts get in here. Can bus questions
