Quick turbo oil feed line question
Old 11-19-2014, 08:32 PM
rawbee's Avatar
Default Quick turbo oil feed line question
First turbo build on my ls. I want to make sure I get oil pressure over to my turbo's. I ran a T off my oil sender port and ran -4an line to my turbos. It's not a Y fitting it is a T. I have oil pressure on my gauge but I have a relocated oil filter housing and running my pressure sender off that housing. I know this might be a rookie question. But I wanna make sure before I go and start this thing and try to drive it without oil to my turbos.
Old 11-19-2014, 11:05 PM
RonSSNova's Avatar
I just spun mine with the starter until I had oil at the turbo.
I also removed the oil fitting at the turbo just prior to first fire to ensure the turbo had oil.
This was all recommended by forced inductions.
Ron
Old 11-23-2014, 12:02 PM
rawbee's Avatar
Thanks Ron I actually did get pressure from there with the T at the back. I am now battle a low oil pressure issue.
Quick Reply: Quick turbo oil feed line question
