removing Procharger 8 rib crank pulley
2014 camaro going under the knife for a cam swap DOD/VVT delete, never messed with a procharger before, rest of the parts came off easy enough but the huge crank pulley is the issue at the moment.
I removed the 6 cam lock bolts and camlocks, As well as the crank bolt.
I'm assuming I need some sort of puller, anyone know which kind I need?
