Will this wastegate placement work properly?
Old 01-03-2015, 11:35 AM
JustAFooL's Avatar
Default Will this wastegate placement work properly?
Just curious if this will work ok? I will shorten the straight piece going to the gate itself but I was just curious on whether I should have it connecting to the merge on an angle or if it need to just stub straight out the side.. BTW, I give welding lessons on the side if anyone is interested..
Old 01-03-2015, 11:57 AM
dmaxvaz's Avatar
It should work.
Old 01-03-2015, 12:22 PM
66Chevellelq4's Avatar
It looks like it should be decent. What size is your gate? If it has trouble keeping boost down you can always move it fairly easily. That looks like the best spot for your x over though
Old 01-03-2015, 02:25 PM
LILHEMI's Avatar
60mm gate = literally put anywhere and run 2 psi.
Old 01-03-2015, 02:51 PM
JustAFooL's Avatar
It's a 50mm Emusa gate. I may go bigger if I need to. Done cut the hole do no turning back now
Quick Reply: Will this wastegate placement work properly?
