Twin Turbo Caddy Exhaust @ SNL Performance
No problem at all. Sorry I took a small vacation
It is a cxracing x-pipe, its $90 I believe. Way worth the time and materials for that.The welds looked solid, and no real slag inside.
I have used a DrX, Magnaflow, "another brand, trying to remember", and now this one.
Not a problem at all, if you get one, let me know what you think!
Depending on the work at hand I will back purge. Most exhaust systems I don't. A good solid cut and belt sanding pipes flat, make for a really solid and clean weld, with minimal to no "slag" inside. On Mid-pipes, x-pipes, and things that don't require a whole bottle of argon I do. Argon got expensive! If someone required it, I would.
