5.5" to 5", 45 Degree Reducing Elbow Needed
Old 03-03-2015, 10:42 AM
Razor's Avatar
Default 5.5" to 5", 45 Degree Reducing Elbow Needed
As the title states,
I am in need of a silicone 45° reducing elbow. One end needs to be 5" and the other 5.5".
I have found just about every other combination during my searches but have come up empty handed on what I need.
If you could post a link to where one can be bought, I would appreciate it.
Old 03-05-2015, 01:48 PM
chevy69's Avatar
Hope this works for you…
http://www.danvilleperformance.com/p...es-45-degrees/
Old 03-05-2015, 02:59 PM
Forcefed86's Avatar
For inlet piping or charge piping?
Old 03-05-2015, 10:46 PM
Razor's Avatar
Inlet piping. I already have the piping and filter which are both 5" diameter. BW cover has a 5.5 inlet
Old 03-05-2015, 11:57 PM
LT1RAY's Avatar
Would something like this work?
http://www.intakehoses.com/mm5/merch...uct_Code=45L55
http://www.intakehoses.com/mm5/merch...uct_Code=55R50
Old 03-06-2015, 07:38 AM
Forcefed86's Avatar
Reason I asked is you can get the ring adapters for inlet piping and use a more commonly sized coupler. For example I used the popular low profile K&N filter that is only available with a 6" inlet diameter. Then uses a 5.5" to 6" ring adaptor.
This site is also great for inlet piping rubber diesel couplings.
http://store.airflo.com/rehoin6to5.html
Old 03-06-2015, 09:08 AM
oscs's Avatar
This guy always has what I need. He even delivered a few pieces while I was on the dyno (blew my charge pipe off due to shitty clamps)
Quick Reply: 5.5" to 5", 45 Degree Reducing Elbow Needed
