Another non intercooler e85 question
Ive read a bunch of threads on intercooler vs intercooler. People that have ran no intercooler on e85 love it, but if they havent tried it they dont talk good about it Hellbents10 seems pro non intercooler and e85 on lowerish boost.
I have a 408, 10.8:1 compression ratio. I have a s475, probably wont ever run over 15psi, and it will be on e85. Pretty much 100% street driven, daily driven as much as possible, just going to the track once in a while. I know intercoolers are one of the cheaper parts of the system, but if i can get away from running one and still have the truck perform right, why not? Less piping. Yeah if something in the turbo goes to **** parts will go in the motor. I get that, dont really care about that aspect of it.
Im asking from a perfomance stand point, on a street driven truck with max 15 psi, would you run an intercooler or non intercooled?
Id would like to see an non intercooler e85 build with dual meth nozzles. Id say another big aspect would be a properly sized turbo. Like a large t6 on a 370 or so I think would be fine.
Hopefully people that have done it will chime in.
Turbine efficiency does wonders.
Use the largest turbos you can spool or are allowed by rules.
Think about it, a large lumbering turbo builds less charge heat per # of boost than a small, tightly turned unit.
CFM is key.
CFM is key.
Im about to run a non intercooled front mount setup. I had a non intercooled mid/rear mount turbo setup with no issues I ran a single meth nozzle pre-IAT sensor also but eventually sold the meth kit. New setup will be...
-LS3 6.2L SBE aluminum shortblock
-317 heads
-LJMS cam
-S475 T6 1.32 a/r 96mm turbine
-E85
-non intercooled
-317 heads
-LJMS cam
-E85
-non intercooled
-317 heads
-LJMS cam
-E85
-non intercooled
-317 heads
-LJMS cam
-E85
-non intercooled
You have me thinking now haha. Id love to ditch the IC and all the piping and just run a nice clean run from turbo to tb. Id loose a bunch of weight. I could even move my radiator and ac condesor to where the Ic was. Would get better air flow to those and I could put what ever size turbo I want in front the balancer. I think my next winter project is planned out.
Would you mind sharing the timing table and how much timing you pull per IAT temp increase? Or whatever strategy you use to pull timing. All the successful "hot-air" guys I've asked don't want to disclose this information.
Thanks!
I can only imagine what kind of power and tuning window you'd have access to if it was intercooled but again you said no ignition adjustments are possible with the ECM you're running anyway....
Been a long long time since i ran anything w/o an IC lol
Thanks for the reply, looking at a hot air setup for the next project, just trying to get a handle on it. We usually triple the NA HP (and then some) on the intercooled SBE E85 stuff. Seems like alot of the good running hot air cars make pretty respectable NA numbers and aren't leaning on the turbo as much.
Restricted User
One thing to consider, is running some of the lower flowing stock head castings without an intercooler effectively lowers their power potential due to higher IATs.
Volume of air changes by 1/273 for every degree celcius it is heated. So if your IATs would be 110 degrees F with an intercooler compared to 260 degrees without, that 150 degree difference is 83 degrees celcius. 83/273 gives you a correction factor of about 30.4%. So your basically trying to move 130.4% as much air through your heads as if you were running at 110* IATs. If your heads are a restriction, lowering your IATs will allow you to cram a lot more air through them.
Aftermarket heads or even ported castings should be able to make due without an intercooler on a smaller inch motor.
