pick the best out of these turbos for a 347ci rear mount
1. 76mm .80 ar cold side with a choice of .68, .81, .96, 1.0, or 1.15 hotside
2. 78mm .80 ar cold side with a .96 hot side
3. what worked for you.
car is stock comp with a 60mm garret .81 hot side on it now and its a restriction above 5k for sure.
Thanks!!
Thanks!!
All the info is on on3 performance website. I run 93 with meth pushing about 12 lbs on stock comoression. Stock cam too but will replace in the future with a tick grind ir similar
