t6 vs t4 size
t6 vs t4 size
s480 t6 vs. t4 both 1.10 are they the same size externally except the flange or is the t6 considerably large. does any one know. I already have to cut the flange out to go from t4i to t4 with the new turbo but if the t6 to t4 1.10 are basically the same size externally I will go t6 to save some coin on the new turbo.
I can tell you a t6 1.32 is a lot bigger than my t4 1.25 about 2" diameter difference not to mention 4" downpipe to 5" on the t6.
im sure there is a good difference. the 96mm to 83 mm housings are different as well.
if you need a good measurement for a t4 1.25 I can measure mine if it helps mine is a s480/83 mm
