Size of fuel line for FI
Ya what kind of fuel. If its 93 octane with meth injection you could use the stock line. If its e85 you would go with a -8 or -10 feed and the same or slightly smaller for return.
Mine did 900whp with the stock feed and the evap as the return. But I use a lot of meth so my injectors are only at like 60%. Basically it depends on the fuel you are using.
