Loud alarm on STS turbo
Been having issues with my 2001 Camaro SS turbo. Initially having intermittent problems with starting the car and turbo wouldn't spin. found out small piece of rust was binding up the turbo. Removed the rust. Then the car stopped wanting to start. Found out it was the BCM. Replaced it. Now the car has this loud alarm that wont go off unless I disconnect the wires. The wires look like an audio jack that connect together behind the glove box. Took a picture of this box that the wires feed into. The wires also go through firewall and travel down the firewall to the drivers side and go by the fuse boxes. Im not sure whats causing this. My car is also smoking pretty bad. Im getting the car looked at in the next couple weeks but was hoping that I could get a little input or ideas of what could be causing this. Any help or advice would be greatly appreciated
Definitely appreciate the advice. That's exactly what I will do. im assuming this is the same reason why my car is also losing oil???
