Variable speed fuel pump via holley(or any stand alone ems)
I am wondering how well the pump is holding up. I've been reading a lot about this stuff and it seems that brushed electric motors don't really like running at a reduced voltage. However, brushless motors seem to be the way to go.
Andrew
Andrew
The solenoids themselves can get very hot though depending on the freq you run them at and will have a short lifespan without a good heat sink.
I was under the impression PWM controlled SSR relays don’t use lower voltage. They pulse a steady bat voltage to vary the speed. This shouldn’t harm typical brush style motor. They are used very commonly these days to control fan speeds in most cars, which are all brushed electric motors.
For anyone that wants to know more, here is a link that is interesting....start at post #54...
http://forums.holley.com/showthread....-PWM-Fan/page6
Andrew
Andrew
check out a grand caravan van controller as well.
It's also the correct frequency to work if you want to run PWM on the fan output on gm computers.
https://ls1tech.com/forums/conversio...connector.html
