TVS 2300 fuel filter/regulator questions
Hello all
I have a 2005 LQ9 stock bottom end with TSP 225R cam, TSP beehive springs, TSP pushrods, LS7 lifters, High volume oil pump, BTR trunions, untouched 317 heads with LS9 gaskets and ARP bolts. My question is around fuel supply. I have the TVS 2300 coming and wondered if the stock corvette filter/regulator will be enough to keep the bigger injectors happy. I think the kit comes with 60lb injectors. The fuel pump that I will be using is a aeromotive 340 stealth, which I have been told by aeromotive is enough for my current setup. The TVS 2300 will be set up for 6lbs of boost. Should I spend the money for a better regulator and high flow filter or will the stock corvette filter/regulator work? Magnuson said it required 58lbs of fuel supply/pressure.
Thanks for any input
