Question about heat wrap for a turbo...
So I have fixed almost all my turbo clearance issues, however there is still one I haven't figured out yet. There are metal (I think factory aluminum) coolant lines on the passenger side of the engine bay that my passenger side primary is touching. I plan on heat wrapping the primaries with titanium lava heat wrap (rated at 3000 degrees Fahrenheit), but I still don't like that it hits the unprotected coolant line. I don't want to go through the PITA of moving and refabricating the metal coolant line, so I had planned on shielding it instead.
My question is, which would be better? Using the titanium lava heat wrap (same wrap I used on the primaries) rated at 3000 degrees? Or should I use the standard high temperature Aluminized heat blanket rated at 2000 degrees instead? Numbers to numbers it is obvious, but I don't know enough about the difference in design to know if the heat blanket is more of a reflective material meant to block the temp more than the heat wrap would be or not.
