Turbo ID
Turbo ID
I have two of these turbo's and not sure what exactly they are. I know the center housing and turbine/shaft is Garrett, but the compressor housing and wheel are a mystery. The housing has been polished so no #'s at all. The compressor wheel has 1792-23 on it and measures 64mm/90mm by 45mm tall. The turbine wheel has 410114-50 on it and measures 62mm/74mm by 30mm tall. It is a big shaft and had spiral locks holding the bushings in so I think it was built by a repeatable shop. It kicked one of the spiral locks out and chewed up bothe wheels and the housings. I would like to rebuild these or find a pair that is real close as these worked great. Car went 9.67@141 and made 801whp on a stock 5.3. Any help would be great.
Here are some more pic's. It is a large shaft turbo. Maybe someone could give me the name of a good rebuild shop I could call or a member that knows garrett turbos?
3" inlet/2" outlet
3" inlet/2" outlet
