Emusa 50mm wastegate. Dual port or single??
Hooking up an eBoost street and this is really the only part I'm confused on. The wastegate is the typical 50mm Emusa and has a port on the top as well as one on the side. Currently it's pulling vacuum from the driver side of the intake where the fuel eVap was at. Running it from the side port and the top vents to atmosphere
The hook up for the solenoid is totally different when it's single/dual port. Can anyone tell me which one this wastegate is? I've looked for an hour or so and can't figure out what I need to use.
