Supercharge the LS2 or LSA
Here's my situation........I built my 66 Impala a couple of years ago 2006 GTO LS 2 drivetrain,,,,,,Great car very happy........but...in the meantime I built a 66 Chevelle with LSA power........After driving the Impala it just doesn't measure up anymore...............So.........Here are my options.......Put a Edelbrock or Magneson blower on to make it more driveable (Torque)..........The car will never be raced........JUst a Power Tour Highway car...........So........I can Boost the NA high compression LS2........Or....I can sell the engine and buy a crate LSA and after selling the LS2 I will only be a couple of grand away from having a engine that was designed around the Blower..........Opinions ????????
Thanks in Advance
Ken
Thanks in Advance
Ken
I was wondering what you were going to do with the Impala after you built the Chevelle with all that new HP. I'm glad you are keeping it.
Go LSA. If you were on a super tight budget then LS2 but I think you know the LSA will be the easier more reliable route. There are a few other factors also. Do you plan on using the LSA Electronics or adapting your existing LS2 electronics to it. If its the latter, the LS2 might be easier.
I was going to suggest the 525 GM crate engine and was interested in seeing how much horse power the na engine was generating at the lower rpms. I can't believe GM would have such a screwed up graph on their site for the LSA.
http://www.chevrolet.com/performance...gines/lsa.html
http://www.chevrolet.com/performance...ls376-525.html
You can supercharge the LS2, but your head choices are limited to LS3/L92 or LSA, so you're stuck at 10.4:1 compression any way you go. That limits you to stock boost or maybe one pulley size down before pump gas wont suffice
Bear in mind the LSA crate is a longblock with SC, balancer and WP. You still need the SC drive and FEAD, possibly AC too. AC is limited to low mount OEM only. Ive seen custom brackets to mount the AC up high along with the SC tensioner, but they look sketchy for long term reliability. FEAD can be any LSx setup on the corvette spacing. Cant remember what your conversion used, but if its C5/6, CTS-V, G8 or custom plates/Holley LS on the corvette spacing you're good to go
You will need harness mods. If your LS2 is a 58x engine, then you simply need to rearrange some connectors. If its 24x, then you need a converter box or new harness/ECM and change the TB
All in all, the magnacharger kit was designed as an after though added to the engine, so it will be easier to add to a conversion vehicle. Used kits will run about the same cost as a LSA SC conversion with less pulley problems
