NA Cam Turbo Build
NA Cam Turbo Build
Long story short I have an NA LQ4 with a decent size cam. I'm going turbo Denmah style and I was wondering if someone could help me select on of the following turbos for the build. I'm not looking for a track animal just a 80% street build with around 650 rwhp. I know the "right" thing to do would be get a more reasonable cam but I'm looking for the best option of these below.
LQ4 Longblock
Ported and Polished 317
Stock Bottom End
Chinese Head Studs
Truck Intake
BTR Platnium .660 lift springs
Custom Grind Cam 235/246 113+3 LSA
GT45 80 MM 1.15 AR
VSR 88 MM .96 AR
VSR 78/75 MM .96 AR
LQ4 Longblock
Stock Bottom End
Chinese Head Studs
Truck Intake
Intake 235 duration
Intake Lift .620
Exhaust 246 duration
Exhaust Lift .596
Overlap 14.5 degree
Lobe Seperation 113 LSA
Lobe Lift .3650
Intake Centerline 110 degrees
Exhaust Centerline 116 degrees
Turbo Options Intake Lift .620
Exhaust Lift .596
Overlap 14.5 degree
Lobe Lift .3650
GT45 80 MM 1.15 AR
VSR 88 MM .96 AR
VSR 78/75 MM .96 AR
That cam appears to be designed for high rpm performance, so I would get the big 88mm/.96 turbo. Even though the bigger turbo will take longer to wake up, it shouldn't matter (especially on a street car) because your cam is probably already pretty lazy down low.
That's just my opinion, but to be honest, I don't know ****.
Right now its in a lq4 with ported and polished 706 heads connected to a T56 with 4.11 gears, it nice to drive on the street for the most part. Thanks for the help I appreciate the honesty, any other opinions.
Restricted User
S480 with the big 96mm 1.32 T6 turbine.
You'll have a hell of a time hitting 650whp with that cam on any of those turbos. If you start to build backpressure, its all over in the power department.
I was going to say to go with a bigger turbo, but I wanted to answer with the choices he gave us.
If a bigger turbo is at all an option, I would absolutely go with the above mentioned s480l/t6/96mm/1.32 to avoid back pressure.
Overlap and back pressure just leads to exhaust reversion into the intake.
Out of those options gt45 80mm could do it. 77/88 mm turbine side is the biggest out of all those options. 1.15 ar. Edit: actually the 88 is said to be an 8883 so a 83 mm turbine. Now is that exducer or inducer? I assume its exducer? That may be a goof option for back pressure but the 88 wheel is abit overkill. T6 s400 is a proven combo to tho
