Dual vs single catch can with Procharger LS1?
What would the benefit be if I run a dual catch can setup on my Procharged FIrebird Formula? I can't get a response from Saikou Michi for their dual catch can.
Take a look at Mighty Mouse catch cans. His system eliminates the need for a second can. If I'm not mistaken the benefit of a typical system with two cans allows you to catch the oily mess in both boosted & non boosted conditions.
Mighty Mouse system with one can has a boost proof valve that allows for both. Most people here swear by it.
I'm sure someone with more knowledge on the subject will chime in. In between time check out the web site he explains things clearly & the install diagram is self explanatory. I'm guessing you should look at the PCV Can.
