SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'
Old 09-14-2015, 12:34 PM
Spectre86's Avatar
Originally Posted by LANCE ATKINSON
I will get you some pics asap maybe not tonight but I sumped the tank with two 044s and a two 8am lines and Yd them into a 10an feed then returned through factory feed line
awesome. pics would be great when you can man. you still in the stock in tank pump? what hobbs switch?
Old 09-14-2015, 05:03 PM
LANCE ATKINSON's Avatar
Originally Posted by BMR Sales2
Impressive!
You definitely have the car working well with a stout 60ft time like that!
Thanks man!! Its squatting just a little in right rear didnt know if I needed to adjust on it any!?? What u think?
Heads are PRC castings 220s made for small bore kinda. Jason specd em out for my set up.
Old 09-14-2015, 05:06 PM
Nothing in my tank other tan fuel guage and cant remember where hobbs came from I think jegs but comes on at 5 psi if Im not mistaken. If u look at that one pic u can see the bulk heads sticking out of bottom of my tank . They are 8an Ill try to get a better pic.
Old 09-14-2015, 05:08 PM
Originally Posted by sbcgenII
What have you done as far as weight reduction? Is that the torque arm that comes with the M9? What PRC heads, ported stockers or their casting? Car runs awesome this is what i am wanting out of my car. I have drove 2 cars with a 228/232 on a 114 and they both made awesome power.
No AC and bmr k member are only weight reduction. Yes trq arm is what came with M9.
Old 09-14-2015, 11:23 PM
Default SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'
Nice numbers and time man. Got any more pics of the fuel pump setup? Iv got two 044s as well. You still running thr stock in tank?
Here are a couple without wiring. Zoom in and u can see bulk heads with 90s coming outta tank and around to pumps and top left corner is the Y connection
Attached Thumbnails SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'-photo252.jpg   SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'-photo382.jpg
Old 09-15-2015, 10:41 PM
a.white86's Avatar
Lance what's up man, it's Andrew White from Starkville track the other night. Great meeting you man and car is HAULING!
I got out and cut my fan shroud tonight.. And put in some work. Swear your car gave me my motivation back lol. Haven't touched the car in 2 or so months, and now got the itch. I'll post some pics tomorrow in my build thread and bump it so you can check it out
Old 09-15-2015, 11:38 PM
blk00ss's Avatar
my grandma has been faster than this.
Old 09-16-2015, 12:55 AM
😂😂😂😂😂whos car was she in cause I know whos it wasnt!!😁
Old 09-16-2015, 12:59 AM
Good deal man!! Get that thing going itll be wrth it I promise!!! I lost my motivation bad if not for buddys helpn and agging me on it wouldnt be rolln but Im glad they pushed me when my mind was in other places!! Glad orange car could help!!!
Old 09-16-2015, 07:57 AM
Mekkadon's Avatar
Sick car and setup! Combination works well.
Old 09-16-2015, 10:22 AM
Thanks man!!
  #32
DavidBoren's Avatar
I bet that 60' time makes all them t56 rowboats cry a little bit. Damn impressive 60' time. Congrats on the successful build.
Now just go drive the hell out of it.
PS. What, exactly, does prc 220's "kinda" set up for the small bore entail?
Old 09-16-2015, 11:32 PM
  #33
Dropped valve sizes down a little
Old 09-17-2015, 10:52 AM
  #34
93camaro_zzz's Avatar
Nice times man! What does the car weigh? My setup is a little similar to yours. Just not as much power as you yet.
Old 09-17-2015, 09:05 PM
  #35
Im not certain on weight Im guessn 3350 with me in car but thats just a guess so Im gonna run weigh it tomm n see!!
Old 09-17-2015, 09:13 PM
  #36
Grocery getter!! True story
Attached Thumbnails SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'-photo503.jpg
Old 09-17-2015, 11:39 PM
  #37
Car weight without me. 3380
Attached Thumbnails SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'-photo27.jpg
Old 09-18-2015, 01:09 PM
  #38
Spectre86's Avatar
so you have 2 different holes drilled into the tank to sump it?
Sorry for the questions, I was just trying to figure out how to run 2 044s.
I was looking at diesel sump kits but they are all for a single pump. wasn't sure if I should just get one and drill another hole for a 2nd fitting. That's why I was trying to see out exactly what you did.
Old 09-18-2015, 01:55 PM
  #39
Yes there is a flat spot in your tank on bottom. I drilled two holes and used a bulk heas fitting that has a nut inside the tank. Drill the hole to where u have to really wrk to get bulk head fitting to start into it and use a wrench ir deep well socket to thread it into bottom of tank so it will seal off better with no issues. You can run your hand through top of tank to hold and or tighten the nuts inside.
Old 09-18-2015, 03:58 PM
  #40
Spectre86's Avatar
awesome thanks for all the info on it man. what did you seal it with? wanted to make sure its ok for E85 and gas.
Quick Reply: SBE L33 Huron speed V1 pt78/75 23.5psi 5.75@119.90 1.25 60'
