Large frame, forward facing turbo/gear driven Procharger guys in here
So I'm a little stuck on my build trying to figure out placement in my engine bay. I have a lot of room opened up, and am running a large frame t6 single, front facing behind the bumper, with a 5" exhaust outlet splitting into two 3" pipes out of the bumper on either side. What I am stuck on is radiator placement and size. Car will be on e85 and see some limited street time. I know I can easily fit a Honda size radiator (15x14 ish) off to one side, but wondering if this will be enough to keep it cool? My other thought was a short but wide radiator layed over at an angle towards the front to clear the pipes. Does anyone else have pics of their setups with similar combos? What size radiator are tou running and how have you mounted it?
8 Second Truck Club
I've seen some guys that run gear driven prochargers run two radiators, one on either side and they said it worked good. Can't remember if they ran them in parallel or series though, and from what I remember that is important. Also, there have been a number of guys run a big radiator mounted in the rear under the trunk with success. I think skinnies current build runs like that with no issues.
