foxbody turbo build help
I have a 91 foxbody with a 6.0 in it and it has a edelbrock pro x intake and 317 ported heads with a btr cam dur 278 int 287 exh DUR@. 050 int 226 exh 234 lobe sep 116 lift 605 576.I tore it down and put good rings and gap for boost and good bearing and head studs.It has a power glide with a trans brake and 1.82 first gear.This is my first turbo build and any advice as to what size turbo and if there is any bolt on kits like on3performance that would be good.I would like 7 to 800 hp if I could and also keep power steering since it will be a street car.
Looks like a good set up how do you think it would do with my motor and what kind of front water pump and atl do you have on it.And how would the A/W intercooler work for street car.Ive never had a turbo car always been a nos guy but thought I'd try a turbo and see if I liked it.Could you send me some closer pic of your set up.I was thinking single turbo but twins do look neat and dif
Looks like a good set up how do you think it would do with my set up and what kind of front water pump and atl set up do you have on it.And how would the A/W intercooler work for street car.Ive never had a turbo car always been a nos guy but thought I'd try a turbo set up and see if I liked it.Could you send me some closer pic of your set up.I was thinking single turbo but twins do look neat and dif
A/W intercooler is awesome for the street. I love it. Water Pump is a Mezierre electric but the set up clears a stock pulley water pump as well. My alternator is lower passenger side but where you have it will work as well. I just think alternators are ugly and prefer them low.
It's all a preference. These will make north of 800 on pump and 1200 on Ethanol.
The only kit you can buy right now is a on3 but I haven't heard of anyone actually running it to say there's good or bad feed back on it. Otherwise you're stuck having a kit built for your car. Below is a thread I made giving some ideas for turbo setups in foxbodys.
https://ls1tech.com/forums/forced-in...bo-setups.html
For the power you want I would recommend a precision turbo like a pt7675 or a pt88 only for the simple fact there isn't tons of room under the hood without cutting up your car for a Borg Warner. That being said I have a bws476 and we had to cut the frame rail out in my car to get mine to fit.
Thanks for the advice 2002 camaro ss and I'll be subcribing to the thread you started.I was looking at the bw turbos but do hate to have to start cutting a bunch out of my car since it's a street car and may not like the turbo and go back to nos
