3 bar map for truck intake
I'm looking for a 3 bar map to mount in my truck intake in the stock location. I see EFI source sells an LS1 model, but it only has a provision for one of the retention fingers on the intake. Let me know what you guys are using. I already have the brick style that I'll use if I have to, but would rather have one in the stock location to clean things up. Let me know. Thanks.
Restricted User
I believe the idea behind using the stock LS1 style MAP sensor on a truck intake is that if its good enough to be held down by 1 clip on a car intake, its good enough to be held down by 1 clip on a truck intake.
I'm using the same one that Area 51 posted on my truck intake. That may or may not change when I switch over to a TBSS intake in a few weeks.
I am using the efi source one on a truck intake with no issues. I have seen other people zip tie around the two posts to add some support but I haven't done that as of yet.
