Does this sound like a 1000rwhp Capable Setup?
Just wondering what you guys think.
5.3 (pac 1218s 228r Cam)
4L80e stock with Hd2 kit
258mm Billet Circle D triple disk
83mm Bullseye Batmowheel T6 1.32ar
Dual Walbro 450s
-10 feed -8return
Holley Hi-RAM
E85 for fuel
160lb Holley injectors
Holley Dominator EFI
Dual Walbro 450s
-10 feed -8return
Holley Hi-RAM
E85 for fuel
I have no idea what power it equates too but I've run my 88mm up to 26PSI and I'm getting 89-91% out of the Holley 160's on e85. I would think base pressure plays into it a good bit since they flow 168lb at 43psi, 197lb at 60psi and 221lb at 75PSI.
Why does everyone think they can make 1000whp on a stock 5.3 and a stock 4l80e with a shift kit? That stupid hot rod magazine ruined everything. Hope you don't oil down the track too bad when something gives out
forge bottom end, magnafuel + 450 for fuel system,
get good studs and heads with a bit thicker deck
keep in mind 480 will blow and will soak up some HP, the built 480 is a good choice and that convertor sounds like it's up to the task
1k is pretty exciting and will likely tax the chassis as well
