a few boost questions
Old 01-30-2016, 12:49 AM
chevybayboy's Avatar
Default a few boost questions
So I went to get my car tuned put down 525rwhp previous setup put down 470 to the wheels. So when it went to get tuned with 525 and only 6lbs of boost? I'm thinking those numbers are pretty low. So the tuner said it was because I'm running big flowing heads a large cam and lomg tube should the car have put down more power then that? Car also ran like **** he said it was because my car was an auto and o2 sensors were not reading, I put my scanner on and they read fine. So I looked at my bypass valves and they were stuck open even on acceleration I know that would definitely effect my boost and number gains how does this cam sound to you on a
98 camaro ls1 383
238/249 .625 .625
D1sc only put down 6lbs of boost with bpv stuck open its also on 50/50 water meth all input is welcome
Old 01-30-2016, 10:22 AM
Restricted User
JoeNova's Avatar
Was the 470 number without boost?
Old 01-30-2016, 10:32 AM
Yes the 470 was all motor
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
If your bypass valve is open it won't make any boost at all. When the bypass valve sees near zero vacuum the valve will close, when then directs the boost into the engine. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 01-30-2016, 10:34 AM
LS1Tech Sponsor
I would also run 100% methanol, as a water mixture can put out the flame. Bob
__________________
Old 01-30-2016, 10:41 AM
I think the problem was the the vacuum was plumbed into the break boost vs the intake. It would close at all. When I hooked it to the intake port it closes when I hit the gas. And ok Th the methanol I'll look into running Stai ght meth
Quick Reply: a few boost questions
