Info Please
Old 02-02-2016, 06:18 PM
vht
vht's Avatar
Default Info Please
I'm trying to find out if I need a spacer and bolts to run a 400 turbo behind my 06, 6.0. I've been told both ways and I just need an answer from someone that has done it.
Old 02-02-2016, 06:27 PM
forcd ind's Avatar
I use the 4L80E flywheel setup on a 400, as long as the converter has the standard snout on it
Old 02-02-2016, 06:31 PM
vht
vht's Avatar
I'm going to use a regular turbo converter, and my flywheel is the flat one. I've seen some that has the dish, but I don't know what yr it came off of.
Old 02-02-2016, 06:41 PM
yenkomike's Avatar
I have the stock 6.0 flat flexplate and use a stock 400th converter for sb or bbc in my nova. no spacer needed for 6.0 .
p.s. 5.3 and 4.8 need the spacer.
Old 02-02-2016, 06:46 PM
vht
vht's Avatar
Thanks YenkoMike. That's what I need to know.
Quick Reply: Info Please
