Holley Sniper intake review
Old 05-23-2016, 12:15 PM
Black89Z51's Avatar
Possibly but would it make much difference at 25PSI? I noticed the Edelbrock Pro-flo doesn't have stacks but rather beveled edges leading into the runners. It picked up a good amount over a stock intake, so much so I had to reassess my fueling situation. The pro-flo gained 58hp over stock in the NA intake test but I've seen boosted dynos gaining much more.
Since pressure is just a measure of resistance to flow, a better flowing path may decrease pressure slightly but raise flow, increasing power.
It's all hypothetical until someone tries a stock one and the chops up another one and does back to back tests.
Old 05-23-2016, 12:19 PM
rotary1307cc's Avatar
Originally Posted by Black89Z51
To me, it looks like the stacks on the inside of the plenum would hurt more than help. Air coming through the TB is going to pile the side of the stack and create a ton of turbulence inside the plenum. Also, the turbulence is going to kill any velocity you have going into the intake. The plenum around the stack kind of negates the benefits of a velocity stack.
I think it would make more power if you cut the stacks off on the inside of the plenum.
You better look into intake manifold design some more
Really the only thing "not good" on these is the lack of plenum volume
Old 05-23-2016, 12:28 PM
The manifold does as its design dictates.
Here is bolt on ls3. Back to back ls3 intake vs this intake (near clone/minimal plenum differences)
It looses down low and gains up top just as you would and should expect
Old 05-23-2016, 12:37 PM
Do you think velocity in the plenum is your friend?? The entire point of a large plenum is to reduce velocity
Look at this marcella Intake, guess here the TB is in relation to those runners in the way...
Old 05-23-2016, 01:22 PM
stevieturbo's Avatar
Originally Posted by LJMSJohn
On a 1200 rwhp F1x blown 427, that intake made 40 less rwhp than a stock LS2 intake.
Any side by side graphs to show where the losses etc were made ? Was it a back to back test, no other changes ?
Old 05-24-2016, 08:17 AM
mOtOrHeAd MiKe's Avatar
Location: Ottawa Ontario, Canada - where arguing "DA" is for the slow and weak...
Good on you OP for taking a chance! I know I caught a lot of crap when I bought a Holley Mid-Rise intake instead of the High-Ram to install in our TBSS because I didn't want to jack-up the cowl. And you know what? It fit great and works fine.
Old 07-07-2016, 08:23 AM
sschoeffler's Avatar
Originally Posted by brutalis
What kind of motor mounts do you have?
Back to poly mounts. Bought solid mounts but they didn't get along with the BMR turbo kmember
Old 07-07-2016, 08:25 AM
Old 07-07-2016, 09:35 AM
Randolph Ziskey's Avatar
Your set up looks killer!!! ^^^
Old 07-07-2016, 10:38 AM
FourG63 97GST's Avatar
interesting, I'm how the powerband looks when boosted. I currently like the low end torque stock intakes give. the boost will fix the top end drop offs
Old 08-18-2016, 09:00 PM
GarrettM's Avatar
Any updates?
Old 08-18-2016, 10:35 PM
  #32
tony2424's Avatar
What's the part # for the intake? Looking to do the same thing. Thanks.
Old 08-18-2016, 11:35 PM
  #33
Game ova's Avatar
Originally Posted by sschoeffler
This engine bay needs to be flagged as pornographic material.
Old 11-16-2016, 08:17 PM
  #34
BigAL383's Avatar
Any updates on how this intake is working with your set up
Old 11-16-2016, 08:22 PM
  #35
tony2424's Avatar
I'm making 22psi on mine. It has been working great zero issues.
Old 11-17-2016, 10:40 AM
  #36
SLOW SEDAN's Avatar
You know what kinda power it made on 22? On what turbo?
I've seen this intake go 151MPH on ~15-16psi on an S476 in a 3600lb car with conservative timing. Doesn't seem like intake is starving anything for air.
Old 11-21-2016, 10:05 AM
  #37
Juiced2002's Avatar
9.27 @ 151 with a 1.58 60'
15 psi and low timing... Sniper working fine over here!
The following users liked this post:
2001$Tingray (07-07-2023)
  #38
Juiced2002's Avatar
Holley Sniper intake review-photo457.jpgHolley Sniper intake review-photo537.jpg
Old 11-30-2016, 11:59 AM
  #39
pozesd99''s Avatar
Anyone have an idea of how this intake might stack up against a ls6 intake on a na stroker motor? Seems all the test are with boost
Old 11-30-2016, 12:04 PM
  #40
If you turn over 7k, then the Sniper will probably see some benefits.
Quick Reply: Holley Sniper intake review
