1st gen Camaro 427 LSX 6 bolt trickflow heads twin ETRHO76mm 7.74@183 stock ls3 intak
Old 09-06-2016, 11:05 AM
  #61
Bad Apache's Avatar
Originally Posted by denmah
After seeing that pic, I'd be pinning that hood down in the middle, lol. Awesome car! Makes me wonder if the wife would mind if I cut up hers?
Old 09-06-2016, 11:51 AM
  #62
SLOW SEDAN's Avatar
Congrats! Badass car. Could you get away with E85 and 15 degrees at 26PSI? What do the turbos have left in them?
Old 09-06-2016, 12:49 PM
  #63
Moderator
denmah's Avatar
the hood is actually ok, that is the grille with no support shoving back
we could probably go 7.8s @ 176 on ethanol yes, we would have to see how far it can go on injector, i think the turbos will hang the rods out on kill honestly
Old 09-06-2016, 01:27 PM
  #64
Restricted User
JoeNova's Avatar
Do you or Mark have any theories behind how this one performs vs the notch?
Similar ET and MPH
Camaro: 427 LSX, TFS 6 bolt heads, Twin Billet ETR 76s, LS3 intake. 26-28 PSI(?)
Notch: 402 stroker, Stock 317 heads, Single billet 84, LS1 intake. 22-24 PSI(?).
It seems like the Camaro should be significantly faster even on the same boost. Somewhere in the 7.50s on the current setup. I know it weighs a few hundred pounds more. Any chance the converter is struggling? I'm at work so I can't view images/attachments so I'm not sure what the 60 ft on the notch looked like vs Camaro, but that could be it.
Old 09-06-2016, 01:42 PM
  #65
svslow's Avatar
Similar ET and MPH
I am wondering the exact same thing.
Old 09-06-2016, 02:33 PM
  #66
ablakez28's Avatar
I dont recall but what did the Notch trap? I know it was insane fast for what it had for sure. My guess is being still shakedowns they are figuring out the power management of the 330'/front half still. While the notch was amazing this still to me to go 7s so quickly on a new build astounding. My setup is almost identical and in two outings so far ive mostly just done promod burnouts down the track. Id be happy to ever have that slip above!
Old 09-06-2016, 02:39 PM
  #67
Moderator
denmah's Avatar
yeah we cant use all the power yet, still on a long ramp, also 400lbs heavier and smaller tire
its already out trapping the notch on the same boost with less tire, more weight, and longer boost ramps
Old 09-06-2016, 02:43 PM
  #68
ablakez28's Avatar
Very nice. I have been too greedy and thought i could handle 20psi .8 sec off the brake on leaf springs and a radial. fun ride though. Heading back out soon on menscer coilovers and a little softer tuneup.
Old 09-06-2016, 04:08 PM
  #69
Moderator
denmah's Avatar
oh and yeah i thought the same thing, i figured this motor and combo would make huge power on low boost, but it does not, but it keeps gaining like a beast up top. oh well
the white mustang was a unicorn to measure all other vehicles though so much with so little we can all only hope to do as well as that little fox did LOL
Old 09-06-2016, 04:55 PM
  #70
madmike9396's Avatar
To much damn awesome in one thread. Mind blown lol
Old 09-06-2016, 09:37 PM
  #71
Tomhames's Avatar
Thanks for posting the video on FB. Just watched it!
Car looks great- good job.
Old 09-10-2016, 09:09 PM
  #72
Byrdman11's Avatar
Love this build keep up the updates. I see u are running wet sump oil system how hard do u turbo the engines and shift it?
Old 09-11-2016, 11:28 AM
  #73
Moderator
denmah's Avatar
unsure what you mean with hard do turbo the engines? auto correct?
anyway 7300 ish rpm
Old 09-11-2016, 04:01 PM
  #74
Byrdman11's Avatar
Sorry about that. Your turning the engine 7300ish and shift the same? I'm hope to turn 7500 with and wet sump system myself. Your build is awesome and making me feel better about turning 7500rpm. The pt 106m turbo with g-trim turbine need all the help to spool. Thanks
Old 09-11-2016, 06:56 PM
  #75
Moderator
denmah's Avatar
yeah it is wet sump and i have limiter at like 7500ish right now because it traps at 7334 lol
i mean its like 15 passes total now but no issues.
he is planning on gear vendors over winter, since we like this gearing and power right now, and the longer gearing with the overdrive on the street will be nice, we can also bump the gear vendors 1000ft under full power, pretty neat.
Old 09-15-2016, 04:22 AM
  #76
slowlsx's Avatar
8psi launch 3900rpm
26psi up top short ramp
7334 rpm through traps, mickey pro 275 radial tire
100-140deg intake temp rise over pass
11.50 Average air fuel 15deg timing.
3300lbs, she is a rocket!
I'd be interested to see more pics and which intercooler or Intercoolers were used!! 40* rise with that much boost is impressive
Old 09-15-2016, 08:27 AM
  #77
Moderator
denmah's Avatar
Attachment 720621
Attachment 720620
Attachment 720917
Old 09-15-2016, 08:36 AM
  #78
Old School Heavy
speedtigger's Avatar
Now that is some intercooler.
Old 09-15-2016, 09:43 AM
  #79
slowlsx's Avatar
The first picture it shows the outlets at the bottom... wonderif those ports make the Intercoolers tie into each other or were they blocked off completely then the side outlets were added.
Looks like th cxracing 5" core
Old 09-22-2016, 03:01 PM
  #80
Moderator
denmah's Avatar
yeah they completely changed the in and outs to be horizontal and fit the car, then welded the cores together, each turbo gets one of those cores, the pipes cross in the fenders but they are regular horizontal flow, no funny business
Quick Reply: 1st gen Camaro 427 LSX 6 bolt trickflow heads twin ETRHO76mm 7.74@183 stock ls3 intak
