First drive in turbo project: Change gears?
Tall gears are a definite plus for turbo vehicle. Personally, I started out with 295 40 17 et street and 3:23 gear. Went to a 315 35 17 and 3:42......car doesn't pull near as hard.
At what speed does that start? I assume you are traction limited in first. I also forget, are you stick or auto?
Yes, traction is severely limited in 1st and 2nd....often times 4th as well from a roll on. But in comparison between the two different setups.....the et street 3:23 combo was scary in comparison to now. Thinking about switching to done 2:73 to offset these short tires to very that feeling back. This is on the street btw
Just an update I put in 7# gate spring and I was seeing 4.5-5 pounds at engine (think I have a small leak somewhere, possibly boost gauge) and was getting some boost in second finally...glad I didn't up the boost too much because even though I changed target AFR in boost from factory preset 11.9 down to 11.4 I am still getting like 12.2 AFR in full boost so I need to figure out why, thinking it might be because I only have a 30" down pipe and my Wideband is splitting the difference between between turbo and exit
A couple thoughts, just my opinion, from my old blow thru days, that carb hat may not be the best, but prob hood clearance is a factor, and not sure how it affects FI vs boosters on a carb.
Kind of my own opinion with a turbo vs a supercharger, the faster you run thru the RPM's, prob doesn't give the turbo time to spool up, where the latter gears the RPMs are slower, giving time for the turbo to spool-somewhere you hit that happy medium of spooling in the lower gears and the higher gears, lol-of course a lot comes into play, engine specs, etc.
I think that's where those programmable controllers can shine, boost in lower gears and the ability to control boost at the top of the run.
I am still fairly new to turbos after a bunch of Prochargers, so this is just some of my observations, and to much coffee this morn., lol
Just something to check, I had an issue with low boost on my car. On the supposed 7-8 pound spring I was only seeing about 3.5 pounds. Went to the 11-12 pound spring and only saw 6 pounds. I found out I had hooked my vacuum/pressure line from my intake to the wrong port on the blow off valve. I have a JGS 50mm and I had the line hooked to the lower port by mistake. Switched them around and instantly saw 12.2 pounds.
I agree that once you find the boost issue a gear change would help a TON with that ridiculous 1st gear ratio and 3.73's. At least swapping to something like a 3.08 would make it useful and I think more fun to drive all around.
I totally agree that the low profile Spectre hat is not optimal by any means, but you are right that its a hood clearance thing, i hate having to make sacrifices but it is what it is
#32
Did you add an external boost referenced regulator? I was reading a thread somewhere, (I think on YB) about Fitech with blow thru and it said the internal regulator will not work with boost, I believe it said you need to bypass it and use an external boost referenced regulator.
#33
Messed with car tonight and found I had an open vacuum port in throttle body, very dumb move on my part lol...however a 9# spring netted me 6.2# at the throttle body probably a mix of possible small vacuum leak in brake booster, cheap intercooler, the low profile carb hat causing turbulence because I'm getting a slight stumble when matting it from 2700rpm cruise in 4th...guess I just need more spring
