Boost Issues
Old 02-17-2017, 10:19 PM
gixxer9's Avatar
Interesting. I have a cutout right after the downpipe, too. What are you using for an air filter?
Old 02-18-2017, 08:24 AM
RealQuick's Avatar
i was using a 5.5" long filter on a 3.5" stainless pipe that ran from my front bumper to the compressor housing (3 feet of piping). I now run a turbo screen only.
Old 02-19-2017, 11:53 AM
SethU's Avatar
Taking the differences of the two engines out of the equation, isn't the "problem" presented here par for the course with MBC's? A pressure peak then settles to slightly below? Where, if you want constant 20psi, it'll probably crack the MBC open at 22-24 then settle at the desired setting?
gixxer9's Avatar
I may have some extra back pressure, but I was still able to make more power with the larger motor and same hot/cold side. We are going to be looking for a leak on Monday.
Old 02-19-2017, 11:56 AM
gixxer9's Avatar
Quite possibly, but the MBC didn't have as dramatic settling on the 383. It hit 15-16 psi and held at 15.
Old 02-19-2017, 01:44 PM
RealQuick's Avatar
you have boost drop issues with just wastegate too though, right?
Old 02-19-2017, 04:53 PM
gixxer9's Avatar
Yes, I do.
Old 02-19-2017, 05:04 PM
RealQuick's Avatar
Yes, I do.
that rules out boost controller as a cause.
what air filter you running?
Old 02-19-2017, 05:14 PM
gixxer9's Avatar
A large cone type right on the inlet of the turbo.
Old 02-19-2017, 07:57 PM
RealQuick's Avatar
what dimensions?
Old 02-20-2017, 03:32 PM
gixxer9's Avatar
what dimensions?
Approximately 6" at the base and 4" at the top and about 10" long.
Old 02-20-2017, 04:22 PM
  #32
RealQuick's Avatar
can you log a 2nd gear pull on the street with and without the filter?
Old 03-05-2017, 11:12 AM
  #33
gixxer9's Avatar
We have resolved the boost taper by again replacing the wastegate spring with a new 18 lb spring from Precision. It holds 17-18 psi on gate alone, but all is not well....
We turned up the boost and then my ignition was breaking up. New plugs with a tighter gap and new wires fixed this breaking-up, but..
It will not make any more power than 680ish regardless of boost pressure. It is not showing any knock or pulling timing. There is no way that this turbo is maxed out on a 346, right?
Old 03-05-2017, 12:06 PM
  #34
stevieturbo's Avatar
The tuner has total control over timing. The tuner has to determine whether there is any knock or not.
So the tuner has all the information to hand to test whether the turbo will make any more power than that. Boost pressure is only one aspect
Old 03-05-2017, 12:10 PM
  #35
Game ova's Avatar
Could be maxed, especially if it's through an unlocked automatic. That's not a lot of turbo. Didn't see how much timing, or what injectors you are using.
Old 03-05-2017, 03:01 PM
  #36
gixxer9's Avatar
It's a t56. Not sure what timing is set at, but injectors are 80 lb, with twin 340 pumps. I am running 96 octane mix with meth.
Old 03-05-2017, 03:36 PM
  #37
RealQuick's Avatar
can u post the dyno sheet?
Old 03-05-2017, 06:59 PM
  #38
gixxer9's Avatar
I'll talk to the shop to see if they can email it to me.
Old 03-07-2017, 10:11 AM
  #39
gixxer9's Avatar
Old 03-07-2017, 10:35 AM
  #40
MY_2K_Z's Avatar
What fear were you in on this pull? Looks like 2nd
Quick Reply: Boost Issues
