Supercharger leaking oil!! Help
Old 06-27-2004, 06:34 PM
GreenHornet37's Avatar
Default Supercharger leaking oil!! Help
Well today I started to install my guages and I was under the car to hook up the A/F guage t the oxygen sensor when I looked at the intake on the supercharger and noticed oil in the intake tubing. So what is the cause of this. To much gear oil in the supercharger? Is this bad. I also noticed that my belt was toast. I have only had this on for a week. Do they normally go bad this Fast or is the tension to tight?
Thanks
Zach
Old 06-27-2004, 07:05 PM
Grasshopper's Avatar
If you have oil in the intake of the supercharger, the supercharger isn't leaking, you're probably getting oil from the PCV system in there. Try cleaning out the oil and unhooking the PCV line from your intake tube.
Quick Reply: Supercharger leaking oil!! Help
