oil drain to oil level sensor hole?
Didn't find anything difinative on this by searching. Is this a bad idea? I assume that the sensor is for when the oil level is low, i.e. the level should be at or above this hole which would make it a less than optimal place for a turbo oil drain. Just wanted to check before I go carving a hole in my brand new pan. This is going to be for a 6.0L w/ an f-body pan in a 72 chevelle w/ a GT42 turbo.
Max
Btw, how many quarts of oil for the f-body pan?
Max
