Procharger oil change...
This can be done w/o pulling the charger off, right? I really dont want to pull the blower off so i'm hoping that this can be done with the blower on the car. The last time I changed the oil I already had it off the car to swap the belt out and so I changed it then. Theres a flathead bolt on the top of the charger and then the bolt on the bottom(drain plug I'm assuming). I'm guessing the flathead bolt is the filler?
thanks,
chris
thanks,
chris
