Need help with ATI Fan...............
Old 04-12-2006, 04:00 PM
sscamaro387's Avatar
Default Need help with ATI Fan...............
I just got my car back from the shop. and drove it for a couple days, and now the fan does not turn on.
I have a SLP fan switch (that I only use when I'm parked, or if I'm in stop and go traffic)
But, I changed all the relay's, and it still won't turn on (not even with the SLP fan switch) I called ATI, and they said that their fans never go out.
HAs anybody ever had a problem like this?
Old 04-12-2006, 04:10 PM
rwb
rwb's Avatar
If you have done the obvious first (check all of the wires and fuses) directly connect it to your battery and see if it turns on. If it does it's in the wiring.
Old 04-12-2006, 04:14 PM
618HAWK's Avatar
I would check for blown fuse,s.
If ok use a test light at the harness close to the fan-connections and check for power, along with the splices. While turning on the SLP Override switch.
This should point you in the right direction, be it a fan or a power supply/control problem.
Quick Reply: Need help with ATI Fan...............
