Anyone tried Eagle 3.9 Crank?
Im thinking to do a 4.030 BORE with a 3.900 Eagle Crank for an iron 396. The reason for going with a 3.900 crank is because im aiming for 7200RPM shift points (Only way to max out the D-1SC with a SDCE setup running 3.4 SC pulley).
Anyone ever tried a 3.900 crank at 800-900rwhp level? Any problems other than balancing it right when first installed? Is it as strong as the stock crank or stronger?
