my setup ??
my setup ??
here my covette setup , is it enough to but 650 rwhp
./ 347 cid forged/ a@a p1 procharger / 14 PSI /ported heads/ custom cam 224/228/ 581 -114 / 24lb injectors/ racetoinx fuel pump / slp ajustable chine/ 1.8 rockers/z06 oil pump/ z06 intake / bbk 80m TB /LT header ceramic coated / off road x pipe / slp loud mouth exhaust /3.42 grear /3200 stall / custom tune by PCM FOR LESS / water injection / 160 thro./ngk tr8 pluges.
No, you are going to need 60lb injectors for 14 psi of boost in a 346 ci. You're going to need the D-1SC to achieve 14 psi as well with your ported heads and camshaft. Bob
