6.0 Heads=Lower CR?
Old 04-26-2006, 11:42 PM
SeeYaSucker's Avatar
Default 6.0 Heads=Lower CR?
Just wondering if bolting on a set of 6.0L Heads will lower the Compression Ratio enough to run a ProCharger D1SC....I know you can run one with stock heads....I would just feel better with a lower CR with a stock bottom end.
Old 04-26-2006, 11:51 PM
BAD FNZ's Avatar
search button is your friend... you will see lots of comments about this...
Old 04-27-2006, 02:03 AM
ChaseSS's Avatar
yeah it will... if you get them with say a 71cc combustion chamber it will drop the CR to about 9.5-6 to 1
Old 04-27-2006, 02:48 AM
Mr_president's Avatar
make sure to get the gaskits mls 2003 and above!!extra thick mean less CR
Old 04-27-2006, 06:37 AM
80superbu's Avatar
yeah, the 71's take it down about .5cc roughly. Like TondSS said, get a thicker head gasket too. Goin from a head gasket that is .05 thick to .06 drops another .2 (9.58 to 9.38 (roughly)
Old 04-27-2006, 11:37 AM
Thanks for the info guys.
