Largest pulley size on D1SC?
Just curious, what's the largest size pulley can you fit on a 6 rib D1SC?? If 5 inches as an example, approx. how much PSI would it be?
Thanks!
Thanks!
The amount of boost that is going to be made is determined by many factors. A 200 cid engine would make a lot more boost with a 5.00" pulley with the same components as on a 400 cid engine. Exhaust, headers, camshafts, heads, etc all play a part in how much boost will be made. In the end, it becomes an educated guess.
A stock LS1 346 engine with a 5.00" pulley on a 6" rib assembly would probably make 4 psi of boost. Just a guess... Bob
