Help rate cam specs of 218/228 564-577-116 for D1SC BLown forged LS6!
Old 05-17-2006, 05:29 AM
Chicago Crew UnderBoss's Avatar
Default Help rate cam specs of 218/228 564-577-116 for D1SC BLown forged LS6!
Futral cam: 218/228 564-577-116 lsa. I think this would make a pretty good blower cam for my future forged LS6 shortblock putting out between 12 and 14 lbs of boost but not certain.
How much power, if any, do you think this would make over my stock 02 LS6 cam?
Also, do you think brand new comp 918 springs are up for the task of handling this cam?
Thanks F/I Crew!!
Old 05-17-2006, 08:18 AM
CHRISPY's Avatar
I think your IVC is too high for a blown stock displacement motor. It'll peak quite high and require a 7000ish rpm shiftpoint. (I am assuming 116ICL as you didnt state what advance (if any) was ground into the cam.
I would look at something like this for your combo:
Intake Duration - ID 222
Exhaust Duration - ED 228
Lobe Center Angle - LCA (also known as LSA) 114
Intake Centerline - ICL 112
Intake Valve opens - IVO -1
Intake Valve closes - IVC 43
Exhaust Valve Opens - EVO 50
Exhaust Valve Closes - EVC -2
Exhaust Centerline - ECL 116
Overlap -3
I personally like XE or XE-R lobes. I would run a dual spring (921 or PRC double)
Old 05-17-2006, 09:47 AM
chriswtx's Avatar
Old 05-17-2006, 11:06 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I would just say you need more spring.
Old 05-17-2006, 11:33 AM
cablebandit's Avatar
i say 918 would be fine IF you werent under boost. I wouldnt change the cam either.
Old 05-18-2006, 12:13 AM
I would say this cam is ruled out for me! Thanks guys and yes, if i get away from my Z06 cam I will have to go with duals and sell my new 918s!!
Old 05-18-2006, 12:14 AM
I would say this cam is ruled out for me! Thanks guys and yes, if i get away from my Z06 cam I will have to go with duals and sell my new 918s I just installed in my stock blown LS6 motor (b/f i realized i wanted to start building a forged shortblock soon enough!!
